Al K
- 12:25 AM
- Nov 15, 2009
Since I'm not the only one to have a 62-5 "B" with a big block and a 318 radiator,I'm hoping one of you cats can help here. My issue: lower hose clearance around the oil filter. I'm running a 16" flex hose now,and it's putting enough pressure on the filter to slightly unseat the gasket(and it's on tight-the filter,that is) and cause some oil seepage. Tried a 19",and the damn thing kept kinking when I tried to install it. Has anyone found a molded hose(or a couple that can be modified) that makes a SHARP right angle at the radiator fitting,to clear the filter,and then around to the pump housing.? I'm not ready to drop 7 Benjamins on a new Mark 7 radiator(though I want to) for proper hose placement for a B/RB mill,so I want to work with what I've got and put that money into something else. Plus,I had the radiator re-cored last year($$$) and want to get my money's worth!
Any ideas,folks? If I absolutely have to,I'll get the new rad,which also means a new shroud,since I had to modify my current one to fit the 318 radiator. I'm looking at a Grand for all that,and that was planned as my machine work fund.
Oh;I'll get some pics out here later to show my dilemma;might better explain things. As always-THANKS!!!
