Al K
- 1:14 AM
- Nov 15, 2009
OK,I seek the advice of the wise sages of the FBBO. I am not worthy,I am not worthy...
Subject:'62 Max Wedge vs. 906 vs. 452 vs ?? heads on a street driven(with occasional track use) car with a 440. 34-3500 elbows weight. Intended CR of no more than 11:1,but no less than 10:1. Intended cam is Lunati 268 Voodoo(268/276-226/234@.050,.494/.513 lift;could step up to next larger 276 unit),3.91 gear w/ 28-9" tall tires,25-2800 stall converter. 1-7/8 or 2" headers,full 2-1/2" exhaust with good mufflers .
I have a line on a decent-looking set of '62 MW heads,as well as 906s and have a set of 452s on the shelf here. Could I run the 286 pieces "as is"(no porting,just seat work and deck surfacing for straightness) or would a prepped(ported,larger exhaust valves,etc) set of the other heads be a better choice? And yes,a set of aluminum Eddys falls(somewhat) into the equation. I realize that my intake choices are limited,especially if I stick with a single 4-bbl. I think an original MW "NASCAR" intake or a Victor would be my only choices with the 286s,as well as a cross ram w/ smaller cfm(525?) Edelbrock carbs(my preference).
The above is the combination I'd like to run,ANY advice would be appreciated. I'm weighing the costs of various modified "production" head combos vs a set of "stock" 286 pieces. Your thoughts?
