Al K
- 2:13 PM
- Nov 15, 2009
...and other maddening things.
Drove the Sport Fury to work last night,and it was the first time I've driven it at night. When I pulled the headlight switch out,either half-way or all-the-way out,the right side turn indicator on the dash came on,as well as the "bright" light indicator. For one thing,the "bright" switch was off(when I pushed it,the brights came on,and the dash light b/l indicator went out);what bothers me is the right indicator turning on. When I hit the right-side turn indicator(with the lights on), it flashes faintly,and seems to draw more power to operate than using the left side. Also,when I pull the switch to just the "marker" lamp setting(half-way out),the left side marker comes on,but not the right. With the light switch off,the turn signals work fine-front and back. Checked the bulbs(all good) and since the r/s turn signal lamp works fine(with headlight switch off),I know I have power to that point. The switch is new,the fuses are good,and the bulbs are new-and I've tried different bulbs and fuses all with the same result. Any ideas-and if you say "ground",please tell me where this faulty ground may be.
Oh,did I mention that the license plate lights aren't operative either? Gawd,I just love dealing with electrical issues;though frustrating,it is educational. Like,I learned that you can put "@#$%^&*@#$%^" and "@#$%^&*@#$%^&*@#$%^&*@#" in a sentence and it makes sense...sort of.
Like when I go to use my little meter,and discover that the battery is dead,and I can't find a screwdriver small enough to get those little @#$%^&* screws out and the back cover off and boy,that V.O. looks tempting at 8:30 AM(it's Happy Hour somewhere,right?) and,and...
