bdb67rt
bdb67rt
12:13 AM
deerfield ny
Trying to get my gas tank out a 67 rt. Any help on how to remove it? The vent tube is covered with original undecoating. I cant find the bolts. Thanks
Maybe I'm not understanding the question... There should be 1" or so wide metal straps longitudinally, holding the fuel tank in place, up to the body, with J-bolts at the end...
And once those are off you can pul back and twist as you do to slide it off the filler neck. Filler neck can stay in place.
I got it out. Only one strap holding tank. Should there be two?. Thanks for help .
Thanks for correcting me kb67mopar...I must be reffering to '68 on up. :sFun_doh2:
No problem...we all do it. I believe you are correct with the later 68 and up with two straps though you would be my savior there as I have none :notworthy:
