Fan Clutch
67 GTX
5:50 PM
New York
Will a fan clutch from a 64 Mopar bolt right into a 67? I have a standard 7 blade fan and a fan shroud.
Can it directly bolt up to my setup or were there changes to the clutches?
Not sure about a '64 to '67, but I ran a '70 Hemi fan clutch in my '64 Belvedere Max Wedge engine.
It is Hayden part number 1705. Can anyone tell me if that will work?
It's been a while since I've had an early B-Body, but the shaft on the clutch is a little shorter on the early b-body unit putting it closer to the engine....the '62-'65 K-frame put the engine closer to the radiator, (not a lot of room) I found that out over 20 years ago while trying to put a fan clutch set up off of my '69 Road Runner on my '63 Polara...and found out the shaft was longer from '66 on up and wouldn't clear the radiator. The shorter early one should work on your application though.
