Ok, induction hardened seats...
Induction hardened exhaust seats have an inconsistant depth, but Mopar are the best ones I have seen out there. I have seen SBC heads where the valve literally bored a hole into the head. Mopars are deeper from my experience, but that said, since the hardness thickness varies, you should put hard exhaust seats in when you rebuild the head. If a set of heads has already had one or two valve jobs, you are more than likely thru the hardness in spots anyway.
You guys spend a crapload of money on all other aspects of your cars, why would you shortcut your heads? I only charge $96 labor for a set of heads, and then the seats which will run around $4 to $5 each.
Once they are done, you won't have to worry about them again, unless you have some kind of failure, or the shop does not install them correctly.
There is a lot of mis-information out there about hardened exhaust seats. To tell you the truth, I would put hardened seats in all of my motors before I would put some of these trick suspension items, ignition items, cooling items, etc... The original equipment worked just fine from the factory, and still does.
As Rusty mentioned, one area I see people skip is replacing the guides. This is a sure way to destroy a good valve job, even break a valve head off. Do yourself a favor, replace the guides, and put in the seats...:grin:
