696969
Would anyone like to share an effective procedure for bleeding the air out of my coolant?
I just installed a new thermostat and in the process some air got into the system. The car runs cool, but spikes at certain times, especially after warmed up and stationary, such as at a light. Then it may go back down.
I seemed to have gotten SOME of this air out simply by running the engine at mid RPM for several minutes with the rad cap off,
but I don't think I got it all.
I also purchased a Stant Lev r vent cap today, in the hopes that maybe I could use it in the bleeding process. I understand that if you get the car hot, go up a hill and then release the valve on the cap, this will release a lot of the air at this upward angle. I don't know if this is true, but I seem to be reading about people doing it with mixed results.
Thanks in advance!
PS. I do not have a coolant overflow tank. Only a overflow tube that points at the ground. Was an overflow tank standard equipment for all B Bodies?
Thanks in advance!
