cr8crshr
- 9:17 PM
- Feb 13, 2009
- Northwest Nevada
Putting out some feelers here to see how many of you all are using the 440Source Heads. I am leaning in that direction for my 383 re-do build...:angryfire:...and so far what I have gathered from their web site, they are quite widely used for both Street and Strip. The E-Heads are just too cost prohibitive all though a very viable alternative. My build is more of a Street set up with a little attitude thrown in. Cam is rather tame so I am hoping for compression between 8.5 and 9.5 on pump gas. Don't have the piston depth but they do not set...eyeballed...hardly anything in the hole. Pistons are Flat Top Speed Pro Forged, Crank is a stock crank @ 20/20, Intake Manifold is the Edlebrock Performer, Carb is a Holley 750 Vac Secondary dual feed. Not looking for an outrageous amount of HP. Just good clean operation and performance. I had stock 516's re-worked on the build at first, but after all I have discovered as to what my engine assembler did on the original build, I am not comfortable with them and figure an Aluminum upgrade would be a better option than an Iron Head. All replies are welcome...:headbang:
