exhaust manifold 440 roadrunner
yannick47
11:10 AM
qatar
right i want to take my headers off my roadrunner ...it leaks,,temps are up etc etc can i put on any exhaust manifold for an 440?for example a one from a truck or something?
Just get the HP manifolds correct for your year. There's an asston of them out there.
The only problem you'll have is getting a piece fabricated to connect the exhaust manifolds to the pipes, but any exhaust shop can do that.
anyone on here with one?i tried to get some on ebay but couldnt find any??
What car and year???
I have 1972's
ive got an 1974 roadrunner with edelbrock heads...will the ones you have fit and are they hp manifolds?thanks
I have 1972's
pm;ed
and i have eddy rpm heads??is it alright i run the stock exhaust?
I'll give this a bump.
IIRC, the 74 may be different from earlier models due to the change in front suspension...someone else may be able to confirn, or deny...
I might be able to get a pic or two of the manifolds on my 73 if that helps, but as before...
Pic would be great! I have major exhaust leakage on my driver side manifold.
I took the headers off of my stroker and replaced them with '68-'69 manifolds. I'll never go back to headers again for the street. I have the MP452 version of the Eddy RPM heads. My plugs are not angled as the RPM heads are. My understanding is that, with the RPM heads and manifolds, the plug wires get pretty close to the manifold on the right side. Guessing that high quality boots would eliminate that concern.
