cr8crshr
- 5:01 AM
- Feb 13, 2009
- Northwest Nevada
Well...I got the new rocker arm keepers and spacers/shims done yesterday. Worked out really nicely I must say. I am more and more liking the newer stuff that we can use on our rides. Rusty...You were right on the spacing between the rockers and keepers. It was a tad too wide so I was able to get it to about .016 thousands as opposed to the almost .030 thousands with the older set up. For those that have asked, I am running newer roller rockers and not the cheap ones offered out there. Any way...I fired up the engine and it now actually runs smoother and a tad quieter than before. But that "tinney knock" is still there. Seeing as how I have replaced everything in this engine with all new, it is still there. The only thing left that I haven't even looked at is the possibility of "the lifter bore tolerances" are out and what I am hearing is in fact a lifter rattling around in its bore. From what was supposed to be a simple build now seems to be a complete failure on both my part and the Clown that put it together for me. I have checked the invoice from the work he did and there is no mention of any work done in that area or that needed to be. Now that doesn't mean that there wasn't anything done but at this point I don't know without pulling the engine again and tearing it down to inspect that. But although remote...in my opinion...it is still a possibility. I just wish there was a way to De-couple the tranny from the engine and still fire it up in the car to see if it just still might be the tranny making the noise and it reverberates through the engine. But being as it is a 727, and with the flex plate De-coupled from the Torque Converter there is no way of starting the engine. If I were able to do that then I could either confirm or deny that the motor is the root of the noise and visa versa.
So right now I am at a loss as to which way to go on this. To me the motor seems to be working correctly as it sounds just awesome...if I tune out the knocking...and would like to believe that after 3 tear downs and re-builds that it is right and as should be. I am toying with the thought of either just letting it sit the way it is for awhile and save up some more to procure another 383 or 400 block, buy a stroker kit, and re-build another using parts off of this 383, have the car transported to the tranny shop...I don't want to drive it right now till that issue is addressed...or cut my losses and get out from the project and move on to something else. The latter of which is sounding and becoming more more and more like the direction I need to take. It's getting old real fast and I am wearing thin my patience and wallet trying to build a car instead of finding the most complete and running alternative that I can enjoy. As it sits now, I ain't really enjoying it much. Thanks to all...especially Brother Jon/69A100 and all here that have offered up support and encouragement. Time will just have to tell...cr8crshr/Tuck
