Nope, a little more looking around shows that the big block and small blocks use the same part number lifter so I'm back to square one. I guess I'll pull them and send them back.
I'm surprised... that's weird Comp Cams said "they don't want you to prime the oil system/pump to get the lifters full" ?????, it also lubes the shafts & rocker too, adding/taking clearances away, to be dead on, like as if it were running... Humm I always when installing new rockers & shaft when doing the initial adjustments, I re-prime especially with a hydraulic lifter/camshaft {distributor & pump drive shaft out, spin the oil pump priming rod with a drill, counterclockwise, If I remember correctly} every time I turn the engine, even if it's only 90* at a time, just to make sure any of the lifters, that may have been compressed & loss of any oil are always fully pumped up, the shafts are lubed & rockers are full of oil, then not only do I wiggle them up & down, "I like to spin & wiggle them while adjusting them", after re-priming & the valves closed, that your working on/adjusting & on the bottom side of the base-circle on the camshaft, when you spin the push-rods, there should be a very slight resistance & no wiggle... if that mad any sense
do it like they are solid lifter camshaft adjustment, with valve closed & with a 0.005" feeler gauge, adjust until you get resistance on the feeler gauge, remove the feeler gauge, then turn a full turn {"if" that's the proper camshaft/lifter "pre-load" suggested from the camshaft/lifter mfgr.} & check by spinning the push rod, you should have a slight resistance while turning them....
I did prime it. I did all that you explained, wiggle, twist and cuss. Thanks
I LMFAO when I read that, I completely understand your frustrations, are the lifters an "anti-pump up" style or "variable duration" style of lifter ?? just curious, if so, maybe that may be a reason for the different feeling when adjusting them, I'm out of ideas....
Hears what I've been up to. The tranny is another side job for funds (jeep 5 speed). I really hate Mopars pulley and bracket setups, there must be a million different combo but I think I've finally figured out what I needed. The pulley in the picture is a 3 3/4 deep 3 groove that is an 1/8 from hitting the fan "ouch". After some shopping on ebay it looks as though they also make a 3 groove that is only 3-3 1/8 deep which looks like it will work. I already made the alt bracket and robbed a power steering pump off an old motorhome with a 440 in it so I think I'm on my way. Pay no attention to the rough cut out for the fan in the shroud "it's just a rough cut" I'll later clean it up and weld a 3" wide strip of aluminum around it. As you can see I blotched my door jams, first time using a two stage base and because the corner of the door jam got more paint it bled threw the orange causing me to give it more time to dry which lead to the clear not sticking properly. It needed a little feathering which resulted in sanding threw the orange so hear I am repainting the jams "great". I used paint stripper on the pump and had to make a pulley puller to get the pulley off for a good cleaning, sure is nice having a lathe. I also had a little extra time to install some more insulation. Now for the bad news, do to medical expense's (my wife) the Charger will likely be put on the financial backburner until next year, and can't even begin to tell you how bad I wanted to drive it and I was so close. :icon_pale: I did happen to finally pull the lifters and get them sent back to Comp, they called today and said "yeap they aren't any good and will send a new set" I have to admit I'm a little leery about installing them. I likely spend my time buildind the custom mufflers and shaker hood now that any hope for money has vanished. By the way, since when do hospitals force all of your bill to be paid in one year "that's a lot of doe" especially when you have weakly 200.00 physical theropy bills on top of that.http://www.summitracing.com/parts/cca-822-16/overview/make/dodge No it says nothing about that but hears a link to the ones I appear to have. By the way I'm glad I could offer a little humor although it wasn't meant be. Thanks Bud
Thanks, I shouldn't be such a butt-head laughing, but I've been there too, that's what I was laughing at, not you or your situation particularly... sorry for all your grief, isn't car building a hoot sometimes ??....
looks like enough clearance on the fan to me, progress at-least...
I wish we had a Summit Racing Store closer, that I could walk into, closest one is 3-4 hrs away in Reno/Sparks area Nevada... I get stuff the next day, after ordering in the afternoon allot, when they have it in stock in the Reno store, with no extra shipping charges, so it's hardly worth the long drive both ways, unless I'm already in the area... Only a few things come from the Ohio Location.... I use them allot great service &/or help or even return policies, if I or they rarely mess up too...
who's brand of sound deadening is that ??
MOAR pics, hows it going bud? when are you going to paint it? get the engine dramas sorted?
I would recommend they're "sticky stuff" adhesive as well, it goes on really heavy and really works unlike some of the adhesives that go on like paint.Bonded Logic, Summit Racing I will check it out, thanks for the heads up...
Not my therapy, it's all her. I think seeing what she is going threw made me forget about my problems. ThanksHope all is well with the wife and your therapy... Work is looking good!
