REAR FRAME RAILS , inside the channel
SPEEDYRT1
9:03 PM
alexandria MINNESOTA
hey what should i use to protect inside rear frame rails after sand blasting , before i put , trunk @ transition pans back in the car ?
I agree with Donny. Blast them clean and epoxy primer.
Don't forget the weld thru coating on the lap areas
We have alway's used Dupont self etching primer inside the rail's, and used SEM weld thru on the joint's to be welded. Sometime's we paint body color down inside the framerail's before installing them. Good luck.
