I want to say 130 psi is probably pretty good for low compression piston kb-162 with open chamber heads. My ancient Chilton book says 68-69 383HP is 150 psi. Original 383 hp pistons have greater compression height than KB-162. Mine is like 140-145 with RR cam, rebuilt many years ago with pistons available back then, with same compression height as original. I use blue Fel Pro head gasket and early 70s open chamber heads.
I have 68 RR 4-spd with 3.91. Long time ago when motor was rebuilt, used Isky 270 Mega Cam with 108 LSA, .465 lift, and something like 222@.050 duration. I had a little mismatch going on with cast iron exhaust manifolds, Torker single plane intake, and 28-inch tires(275/60/15). At that time I also had 906 heads on it.
I made the following changes pretty much together: dual plane intake (cast iron and later Edelbrock Performer), factory RR cam Rusty talked about, put 4-into-1 headers back on, and went to 26-inch and now 27-inch tires. I was happier after that. The Isky cam sounded mean but it was just not that responsive for me at the time, the way everything was set up. I had 12-13 inches manifold vacuum with the Isky, have 16 inches with the RR cam.
I always think mine can run better and I spend hours and hours with Desktop Dyno, but it doesn't mean too much because all the cam people measure seat-to-seat timing differently, so I don't know.
Long long time ago, rode in and drove 71 383 RR that was pretty much stock except headers. It still had 346 heads. That car would not shred tires, but it would accelerate and leap into the next gear. It was so much fun and it could be scary.
