What is the dia of a 71-72 B-body factory rear sway bar.
billfury
11:42 AM
staten island ny
I need to get bushings for it and I forgot if it was 3/4", 7/8" or 1" ? Thanks.
3/4" rear sway bar. Let me know where you find a bushing. All that i've found have to be cut to fit. The ones that go on the stem type mount are a weird size too and I can hook you up on the size if you need. Regular front sway bar ones are too thick to use.
I measured it to be a hair shy of 7/8” so for $17, I ordered a set of polly 7/8” bushings from Summit. The ¾ bushings didn’t work. I will let you know how it worked out.
Only seen 7/8" rear and FYI, never seen one on a 71 but I have on 72's.
Here is a 71B rear sway. Its Cop Car only thing.
That 71 have a different appearance then my 72 which is strait across & the 73-74 B-body I have which has a slight curve in the center . Thanks for the pictures Mark. That’s a real cool car.
