71airgrabberRR
Mirror Disassembly 101
These photos show the process and common mistakes made when disassembling your Rally style mirrors. I'm sure there are other ways to do it, so if you have any info please chime in.
Im starting out with a mirror set that came from a 75-78 B Body.
Start out by removing the round trim bezel that secures the remote interior handle tight against the door panel.
Place the remote assembly control lever end in a vice and compress the spring.
VERY GENTLY take a screw driver and pry the 3 prong retainer away from the assembly. If your not extremely careful this part will snap off because it is only cast "pot metal" which is junk at best.
Only pry it as far as you have to and no more.
Here is where you can mess things up quickly. If you go too far or if your unlucky, one of the tabs will break off.
This is what you want to end up with.
Sometimes even if you are very careful the part can still break unexpectedly.
This part is indexed with one of the tabs wider than the other 2 prongs.
Remember this when you reassembly the parts. I have the widest prong shown centered in the photo.
Once this critical step is finished, unscrew the interior control knob. You may have to hold the adjuster cable end head with a set of pliers while you initially break the control knob loose.
Then start prying the area open that secures the remote control cables to the adjuster head.
Once the areas where the adjusting cables were crimped into position is opened up, simply remove the individual cables from the assembly.
This will leave you with the spring and spring guide separated from the assembly.
These photos show the process and common mistakes made when disassembling your Rally style mirrors. I'm sure there are other ways to do it, so if you have any info please chime in.Im starting out with a mirror set that came from a 75-78 B Body.
Start out by removing the round trim bezel that secures the remote interior handle tight against the door panel.- - - Updated - - -
Place the remote assembly control lever end in a vice and compress the spring.- - - Updated - - -
VERY GENTLY take a screw driver and pry the 3 prong retainer away from the assembly. If your not extremely careful this part will snap off because it is only cast "pot metal" which is junk at best.Only pry it as far as you have to and no more.
Here is where you can mess things up quickly. If you go too far or if your unlucky, one of the tabs will break off.- - - Updated - - -
This is what you want to end up with. Sometimes even if you are very careful the part can still break unexpectedly.
Once this critical step is finished, unscrew the interior control knob. You may have to hold the adjuster cable end head with a set of pliers while you initially break the control knob loose.Then start prying the area open that secures the remote control cables to the adjuster head.
