Pistol grip shifter with a 69?
OldToys
11:54 PM
Colleyville
Will a 4 speed pistol grip shifter fit in a 69 Super Bee (no console)? My wife is looking for me a birthday present and I sent her a link on one at Summit Racing they told her they don't carry them for the 69. Can anyone confirm it will fit and maybe a link to one? I'm trying to let her order it since its a BD present. :)
Thanks, Tim
need to make sure it fits---the shifter is either bolt on or it slips in and is held in by a clip. Once that is cleared up, yes--it will fit.
How's this?
http://www.duncan-motor-sports.com/index.html
I know just sharing, get all excited about pistol grips lol Can't let you 4 speeders have all the fun
Here is what I have I am assuming the shifter separates at this connection.
If so I believe I have a bolt connection although it looks like I have pins instead of bolts.
Is that correct?
Call Brewers Performance. They are the Mopar 4 speed Kings. I just bought and installed a new shifter from them for my 70 Bee. They know more about Mopar 4 speeds than anyone and easy and great to talk to it's all they do.
Do yourself a favor & get a Comp plus shifter with a pistol grip handle.
Hey JB where did you get that pistol grip?? It'd be awesome to get one for my Charger until I'm able to swap a 5 speed in :icon_thumleft:
(sorry don't mean to hijack the thread)
EDIT* sorry, didn't see the link haha thanks for sharing!
i have a pistol grip in my 68, but i do have a 76 OD box, th epistol grip hurst handle uses the 2 bolts to hold the shifter in.
but as said, i would definetly talk to brewers performance.
Cool Idea Bigman, I will be doing something very similar, with a modified, console shifter lever from a 70 4 speed E-Body lever & Pistol Grip Handle, in my A727 equipped 68RR with manual VB on a B&M Quicksilver Ratchet Shifter {SFI appr.}, instead of the stock style Mopar linkages, in the very near future...
OldToys Putting in a Hurst style Comp. Plus 4 speed shifter, it would be a bolt on swap.... Good luck
I called Brewers Performance, they said I would need to replace the shifter, and linkage, with a 70 model. Otherwise the new lever would hit the dash. $720.00 for the set. I guess I will stay with the sock. :(
I did this same swap with my 69 Roadrunner- it's pricey but I think it's worth it!
I bought a 68 4 speed RR .. pretty original except the PO had stuck a pistol grip in it. Mine did not hit the dash but came up pretty close but it did in the 70 also. It still looked cool, but I pulled it and swapped the p grip into my 70 RR and put the round rod hurst style you have in the 68 (which is probably a 69 or 70 shifter as most 68's had the Inland brand shifter in them. The 70 had the 68/9 style shift in it when I bought it.
The stock p grips in 70 are slide in and will slide right into that stock appearing hurst shift mech you have.
Really the dash and shifter location are basically the same in a 68 and 70 RR. The floor pans are the same too for a 4 speed replacement floor pan.
Check this vid out and do some more google searching .. ff to 1:40 for an idea of what it would look like
http://www.youtube.com/watch?v=tnfG3ilQ41E
Whoops I just remembered you have a 69. You are all set. Get the pistol grip and enjoy
Over at Duncan motor sports $250 for everything you need. one - two shift like slapstick then have to gate back to drive takes some practice but fun as hell, and when I first put it in it was like having a 4 speed you could feel every shake and rumble from the motor very cool. Makes the car have a whole different dynamic feel.
Duncan has the reverse shifter gate, even has the reverse pattern plate for correct stick placement
Brewers just hooked me up with a pistol grip Hurst shifter, the Hurst shifter mechanism and the proper shifter rods for my non console bucket seat 69 road runner.
Still not sure which one I need, here is one from Summit racing but does call out to fit my year.
Will this fit?
http://www.summitracing.com/parts/huu-5388580
what if you cut the bottom of each shifter and weld the old style on the new pistol grip, will this work without having to change shifter mechanism
