- 12:30 PM
- Jan 1, 2013
- Mascoutah, Illinois
What source brand of paint do you guys recommend for the original turquoise color and or aluminum look paint? I plan to use the Mopar brand turquoise unless there's a better and cheaper one that looks the same or even more accurate. But I'm also thinking of painting it with 'aluminum look paint' to get the clean raw / brand new aluminum look. I don't have home access to any bead / sand blasting equipment and I don't know if it's good to just run them unpainted or painted with clear coat as I've heard that yellows. I could take this one to the local auto hobby shop and sand blast it, but it's been years and I'm not sure how much they charge or if they still have the equipment but thats a possibility. I have no idea if it would come out ok or have stains etc under the paint.
Suggestions please and pictures / what you did welcome.
If I go the paint route which I imagine will be the end result I need something that will hopefully stay on and look good even with the engine heat. I do plan to block the heat cross over.
Here's some photos:
We've used Dawn and water, then Purple foaming something with Kabooom! oxiclean (which does a great job on the interior), and now I'm using oven cleaner - easy off .. full fume version. I'm in the garage and watching the ventilation with overhead and man door open and fan blowing.
Before (after cleaning with Dawn)
Other end after cleaning with oven cleaner, water rinse, then wire brush. I sprayed a test spot on and left it for about 10 min and this is what it looked like after. As you can see it used to be turquoise but i put in on my 70 which was Orange so I painted it black 30+ years ago.
I've been cleaning parts this weekend along with the help of my daughter, thank goodness for her help!. Late last night
Here's some from last night and the underside w/o oven off just dawn and water and then Kaboom oxiclean spray on foaming stuff. BTW it was never painted underneath. I used a razor scraper on the gasket surface.
Here's some photos:
