Did you check your reluctor gap in the distributor? Make sure it's set to .008"? When mine was off it made my car sputter above 3,000 rpm. Maybe you are confusing a sputter from that with spark knock?
That monster cam might very well be suited for a single plane. It's possible you have a major mismatch of parts going on here or as simple as too much compression for the available fuel.
It is funny.. Why not just buy some thick head gaskets, knock the compression down 1/2 point and get in realistic pump gas territory other than borderline? Mine is barely pump gas friendly with 10.25:1 and the 312/590 solid in a 440 based combo.. Can't tell me that doesn't bleed off a heck of a lot of cylinder pressure. I am also only running 32* timing.. Car used to have serious dieseling with my old hyd. camshaft's (meaning, engine still running after car is shut off).. No more dieseling now with the .590 but on very rare occasions.
Supershafts,
I never doubted an 850 Holley or 1050 Dominator would make 'additional HP'.. as we all know, more airflow equals more power. Some of us (not insulting) use common sense when we think of "hp per/dollar". I picked up my race tuned and modified 750 for $150 from a friend... I couldn't imagine spending $500-$700+tuning costs for an 850 in order to gain an additional few HP if any at all. For a street car, you would NEVER notice 5-10HP at the crank. Many aren't running 6,000+RPM from stop light to stop light. An arcing plug wire can cost you that much horsepower! In the second article, the 440 made 550HP. That is no typical street combination with a lil' sub .500 lift flat tappet cam... Many of us don't plan on placing really radical cams in our street dedicated cars, as they are just going to wipe out and go flat in a matter of months with the spring pressure they recommend while we idle down main street in heavy traffic. I ran big lift cams in my SBF's, but they were all hyd. roller and their duration was pathetic! Heck, I run slightly below the recommended spring pressure with my .590 in order to further my durability over the minimal power gains; and it has a slow ramp rate to begin with...
For me, street manners means the ability to run fine on 91 octane and not overheat. It means having the ability to idle in traffic yet still run clean. No clouds of black smoke on startup or full throttle. No vapor locking in 100 degree weather. I'm willing to deal with the vibration and noise. The smell of some unburned fuel is cool. I don't want to deal with knocking, dieseling or the engine being hard to start when it is cold or hot.
261 / 271 @ .050" with nearly 100 deg of overlap is not exactly the type of cam that epitomizes street manners.
Yeah, but this isn't a daily commuter car.
The 750 idled great. It has some lope, but I was able to get it to idle at 600 in gear. I was impressed with how docile the engine sounded and felt. The 850 wanted to flop around and stall below 700 rpms. I drove it and found the Air/Fuel numbers were pretty close to the prescribed goals.
It STILL detonated at 3/4 throttle and above. From a standing start, from a roll, from 3000 rpms it didnt matter. Light black smoke and spark knock. This totally defies any logic I have. I have tried different jets, power valves, carburetors, timing settings, distributors...I've tested it on a warm engine, a cold engine, under 85 degree weather and 94 degree weather. Everything I have tried has resulted in spark knock except retarding the timing.
I am damn near out of ideas. Now it seems like a case of...."When the logical solution does not work, time for the illogical".
I have a few stock 440 distributors I can try. I have different spark boxes/ECUs. I have a 5 gallon can of 100 octane unleaded fuel.
I don't know what else to try.
Try retarding the timing 2 degrees at a time til the detonation goes away. It will probably idle like crap but at least you'll know if you need to limit your advance. Rene'
