Jag fan clutch and fixed fan
am3rican
8:29 AM
Willow Grove, PA
I ordered a fixed blade fan and Jaguar fan clutch. It did not come with mounting hardware (bolts, etc.). I had the flex fan setup before (without a fan clutch). The bolts I have seem to be way to long because they were fit through a 3 inch spacer. I have a 68 with a 440.
Can someone tell me where I can find the bolts? I'm surprised it did not come with any mounting hardware at all.
Also can someone post a picture if they have this setup? I am curious how I mount the fan and clutch to the fan pulley. If I see it, I can figure it out.
bolts not used with fan clutch....studs like yer carb mounting is used. Studs screw into water pump, then pulley slides over studs, then fan clutch with blade goes on and finally nuts hold clutch on. Picture below is best I got
Bryan
Bryan,
Both methods were used,some clutches used a 1/2"concave captive washer bolt depending on the year.
unfortunatley the JAG Fan clutch is not "strong " enough ...you need a heavy duty clutch for the fan with a big pitch.
I made experiences with 6 or 7 diferent fan blades... 5 /6 / 7 Blade..Fixed and with clutch.... now I use a 7 Blade Flexalite... ( only because the Jag Clutch wasn´t working in Summer ( too hot )
Greetings Juergen
Greetings Juergen
Juergen - what did you mean by "you need a heavy duty clutch for the fan with a big pitch." Does this mean that I cannot use my fixed 6-blade fan with this type of clutch? I don't have much choice due to clearance. Should I just try running the fixed blade without a clutch?
Greetings Juergen
Do you really need a clutch at all ? I posted before,factory 3 core radiator,factory shroud fixed 7 blade factory fan,A/C 6 blade pump.180* thermostat,even has A/C,never goes above 195*
I'm having the challenge that I am getting mixed messages. I've even had people even tell me two different things. What triggered this was a tendency for my car to run hot under idle. While moving, the temp gauge went down quickly. I have a 440 6pack without AC.
All I know is that I do not want to keep on running the flex fan. I was running the flex fan without a clutch. I don't mind running w/o a clutch, but the fixed blade fan I purchased can only be used with one.
So...I have a regular duty thermal fan, with a regular duty clutch. The fan doesn't have a whole lot of pitch. Am I risking something by using the Jaguar fan clutch? Is it not designed for a BB? The last thing I want is for the clutch to separate and ruin my hood, radiator, etc.
Well here is what I've heard from various posts and it may, or perhaps not, help you. Obviously I'm hoping help since I just did a conversion much like your a few months back.
In regards to your 1st question: Fan clutches typically don't come with the hardware other than the hardware needed to attach the fan to the clutch itself, not the clutch to the water pump since this is in theory a R&R. Since the clutches typically come with studs, this hardware is nothing more than the nuts themselves. Then again I've received clutches w/o the studs too which required me to remove the studs from the old clutch and install in the new. However in a case like yours, you aren't replacing anything but installing something new. So what to do? Much like you I had a flex fan with a spacer so the bolts were too long. As a result I just went to the hardware store and picked up some Grade 8 (you can use grade 5 but I STRONGLY recommend 8 as it is only a few bucks more and you don't want to cheap out!) bolts with washers to mount the clutch to the water pump. Measure the base of your clutch, the thickness of the pulley and then the width of the water pump mount to give you a rough idea. You obviously don't want the bolts too long but you don't want too short where you only have a few threads in the water pump shaft mount.
As for your other question: I have heard of people running the clutches from jags and no, I've not read of any problems with the fan going through the hood or the radiator. Again, that is what I've read. However the problem with the jag clutches is that they were made for plastic fans and not metal ones. So basically the reported problem is that the clutches seems to suffer from premature failure to where some guys end up replacing them after a year and half or so. They apparently work but not for years, and again this is what I've read.
Like you, I had the same problem converting. I purchased a mopar 7 blade alum fan that came with the no longer made TRW FC28 which is a short shafted clutch that was bad. Any attempt to replace with parts from NAPA, O'Reilly's, AutoZone ended up with supposedly HD clutches that were too long and which would not fit between the engine and the radiator. Not wanting to end up replacing clutch fans I didn't go the Jag clutch route but took some measurements and looked at the Hayden clutch fan measurement info that they have on-line. While some may disagree, and they are allowed to, I personally ended up with a Hayden 2705 which was used on the AMC I6's and V8's. All in all it was a little deeper than the TRW job and moved the fan about a 1/4 inch towards the radiator but so far I've had not problems with it or overheating issues.
So, I'd say run what you have and you should be okay. Use good hardware to mount the clutch to the water pump and you should be fine. Your clutch should work but keep in mind that is may wear out faster than you expect. You'll find out soon enough if it will keep your temps down.
Again, I hope that helps.
One doesn't have to have a clutch fan however it does save a ton of HP (I've heard anything from 5 to 15 HP) opposed to a ridge mount 'mechanical' fan. Electric fans are another way to do go too but the clutch fans are the old skool way of doing it.
I run a non-thermal clutch (no spring in front) on all my cars...moves more air at idle than spring loaded thermal style clutch. At higher RPM's, it disengages because the car is moving fast enough and the air going through the radiator keeps it cool enough.
They say that if a rag can be held to the front of the grill at idle, it's moving enough air to keep it cool
Thanks funship, your post was supremely helpful. I was able to find the bolts after several trips to hardware stores. I ended up going to Pepboys, Lowes, and Home Depot before I was able to find the right length Grade 8 bolts. I used 5/16 x 1" for the bolts to secure the fan to the clutch, and 5/16 x 1.5" for the bolts to secure the water pump. I have drained the radiator and will be taking it out this weekend so I can cut and secure the shroud to the radiator.
Funship32, how far is your fan clutch from the radiator?
Hi Am3rican!! I'm glad that info helped you out.
I'll have to measure the distance and will try to do such tonight. However I've read from others that running the Jag clutches leave them about 3/8's to a 1/2" of inch clearance between the front of the clutch face and the radiator. So if yours seems close, I'd have to say to not be surprised.
Today I installed a FC 28 in my car.... ( ordered the clutch 6 weeks ago !) The funny thing... this FC is a standard Duty clutch also...
but with the 5 Blade Mopar Performance Fan.... this combo makes alot of "WIND".... I let the car idle for about 15 Minutes.... didn´t go higher than 190° F ( with 180 ° Thermostat ) While driving ....@ 180- 185 ° So I am hoping that this combo works in summer also. BTW The Jag Clutch was much "weaker" than the FC 28... ( I don´t know WHY ? )
Greetings Juergen
Greetings Juergen
Thanks Juergen. I may have to take the trial and error approach. I'll see how this Jag clutch works. RE: the FC28, I thought that was discontinued. I may be mistaken. Where'd you source it?
At Hagens Autoparts...$ 145 ea. but this cluth is not a HD Clutch..just Standard Duty.
Greetings Juergen
Tonys parts has re pops of the originals,saw it in Mopar collectors guide.I think they are $200.00
Holy s**t! $200? I'm in the wrong line of work. I looked at a pix of it (Thank you Red 69 for the lead) and it isn't a thermal clutch like the TRW FC28 but it may fit the bill for those wanting a short shafted non-thermal clutch unit. In the meantime I'll stick with my Hayden 2705.
And the 2765's won't lock up as tight at the OEM jobbers. Main theory for that is that they are swinging metal bladed fans opposed to the plastic jobs they were made for.
And Am3rican as for your question: the front of my clutch is 1 inch away from the rad. Leading edge of the fan blade is about 1 and 1/4 inch. And just so all know- I'm running a PO installed 26" radiator..OEM I believe was a 22" for my car. So I cannot say with 100% certainty that this rad would sit or is sitting exactly as an OEM installed 26" would. I just know what I found that worked for me. I've heard of others buying the Mopar Performance clutch w/ fan and finding they don't fit so I guess the lesson is: Measure 2X's and buy once.
...just a idea ! Later today I will give Hayden a call... I will ask them if it would be possible to produce a fan clutch that has the 2747 HD Clutch... with a maximum height of 2.5" to 3.00 "... this would be the perfekt clutch for our mopars... even if the price would be @100 $ each... I am willing to pay .... the price.
Greetings Juergen
@ funship32 the 2705 clutch is thermal....right ? Std. Duty ?
Greetings Juergen
*ROFL*... you were on the same line of thought I was..."maybe I'll contact Haden and see if they can....".
But you correct...if it fits and people don't have to fuss with it, I'm sure they'll pony up a few more $$'s for them.
And yes, 2705 is a thermal. The non-thermal version is the 1705. There is no hd version. They used them in AMC cars including the V8's. And just so we all know: The 2705 is 3.11 inches over all in length. The 2765 (Jag fan) is 2.67 inches.
..hello Funship32
caled Hayden today... talked to a sales man first...he connected me to a guy "Markus " ...spoke on his mailbox... and after 2 hours he called me back ! I Explained "our " problem to him, and told him, that there are so many Mopar Drivers around, having cooling issuesbecause of the wrong fan clutch ! He sayed that many used the 2765 JAG Clutch...and he also thinks that the 2765
is a little too weak for a high pitch BB Fan. I told him that it would be a good idea , to produce a FC with a 2747 HD Clutch on a 2765 "Neck "....as a result the overall height would be @ 2.75 " !! He agreed, asked for my e-mail adress( to keep me informed as soon as he knows something about this issue....
Tomorrow I will try to examine an old FC... perhaps I can "Build a 2747 /65 clone" ..?? I ll keep you informed
Greetings Juergen
...btw... I have a Flexalite 5555 clutch...also. Came off from a 75 Poncho this clutch is also 3.11and fits...( but ..... Standard Duty ::)
Greetings Juergen
HD Clutch..is the stuff , we need !
Actually, Juergen, I don't even know if a HD version is needed. The difference between std and hd is that the hd spins at a faster rate percent wise when compared to a std unit when engaged and that it can handle a steeper pitch of fan. For comparison, a std spins at roughly 60 to 70% of shaft speed when engaged and a HD spins at 70 to 90%. I mean think about it- if people are using the Jag clutches and the fan itself is too hvy or has too much of a pitch for the clutch to effectively handle, the result would be poor air flow/pull at idle. However if a clutch made to handle a metal fan (like my 2705) it would probably be better right out of the gate. The TRW FC 28's I believe were standard units. I could be wrong but they didn't the extra fins on them like the Hayden HD's do. But I'd say lets leave it to the experts. Good call though, I'd be interested to see where it leads.
