Jonnyuma
- 11:34 PM
- Nov 15, 2010
...there's others on here, and I've read most of em, but figured another one couldn't hurt, right. That's what we're here for. Besides, the newest one I've read was from 2012.
I've got a running 76 360 in my Cordoba that I want to rebuild. I'm hoping for a rings-and-bearings job, timing set, oil pump, reseal, etc, but won't know for sure til I get it opened up. The main reason for the teardown is to get at the oil pump, but while its out, well...you know...
Street car only, daily driver, no temperamental racy stuff, please. I've got an AirGap and a 600 cfm vac secondary carb, both of which I'll keep. Also have HEI ignition and have deleted the a/c with the proper brackets and pulleys. I'm thinkin' a relatively low compression, pump gas motor, maybe 350-375 HP and as much torque as I can get. I have stock manifolds and a 2into1 single 3" exhaust which I'll most likely keep (its all PAID for). Headers for late B-bodies start out at cheap and ill-fitting, and skip straight to freakin EXPENSIVE, with nothing in between. Plus, my car sits pretty low, headers would hang too low for me to drive it like I do. Not worth the trouble or expense for a build like this, for a car like this.
The typical budget restraints are solidly in place. If I get off easy in the engine department I can re-bush my front suspension while it (engine) is out of the car: much easier that way. I'd like to use my heads at least til I can afford better ones, so a valve job and seals (and springs) will probably be about the extent of the headwork unless I do it myself. Heads can always be upgraded later. Any good cam ideas? I like a fairly smooth idle on this car: all blublublub as opposed to rumpityrumpity....shouldn't be a problem with a mild cam. TC stall recommendations? Tips on building enuff torque to help a 4000 lb car get out of its own way? By the way, I have a 3.55 r&p to install, I just haven't had the guts to tackle it yet. Between that and the proper tq converter it oughtta at least FEEL fast(er). A cam change and a little bit of head work oughtta make it BE faster, and that's what I'm looking for from youz guyz: a good combo.
Thanks,
Thanks,
