cr8crshr
- 12:02 PM
- Feb 13, 2009
- Northwest Nevada
For a DIY and On A Budget type applications, I have been using the VHT and Eastwood brands for years. Basically prep the manifolds really well prior to application, and they will turn out fine. And will last for quite a while I might add. Except in the case of them being left outside and exposed to the elements 24/7. Then it is only a matter of time and the elements taking their toll. Also remember this...The exhaust manifolds and even headers create a tremendous amount of heat when the motor is at full operating temp. There will be some minor deterioration and finish because of the heat. But unless you are applying any coatings to obtain a 100% resto and will be trailering the car, then they are meant to be driven and shgow some ware...my 2 cents....:coffee2:
