How the Chevy Vega was shipped, not Mopar, but cool anyway.
gdrill
Just enjoying "B"-ing here
12:53 PM
Stuck in the past, just North of Montana....
Remember the Chevy Vega?
This is how they were shipped. Until the early 1960s, automobiles moved by rail were carried in boxcars. These were 50 feet long with double wide doors. Inside was room for four full-sized sedans on a two tier rack, two raised up off the floor on a steel rack and two others tucked in underneath them. This protected the cars during transport but wasn’t very efficient, as the weight of four vehicles was far less than the maximum weight a boxcar that size could carry. When 85 foot and 89 foot flatcars came into service, it was possible to pack a total of fifteen automobiles in one car on tri-level auto racks. But it still didn’t approach the maximum allowable weight for each flatcar.
When Chevrolet started designing Vega during the late 1960s, one of the main objectives was to keep the cost of the car down around $2,000 in circa 1970 dollars. At the time, the freight charge for moving a loaded railroad car from the Lordstown, OH assembly plant to the Pacific coast the longest distance cars produced at Lordstown would need to travel was around $4,800. Since the Vega was a subcompact, it was possible to squeeze three more cars on a railroad car for a total of eighteen, instead of the usual fifteen. But that still worked out to around $300 per car, a substantial surcharge for a $2000 car. If only Chevrolet could get more Vegas on a railroad car, the cost per unit of hauling them would go down.
The engineers at GM and Southern Pacific Railroad came up with a clever solution. Instead of loading the cars horizontally, the Vegas were to be placed vertically on a specially designed auto rack called the Vert-A-Pac. Within the same volume of an 89 foot flatcar, the Vert-A-Pac system could hold as many as 30 automobiles instead of 18. Chevrolet's goal was to deliver Vegas topped with fluids and ready to drive to the dealership. In order to be able to travel nose down without leaking fluids all over the railroad, Vega engineers had to design a special engine oil baffle to prevent oil from entering the No. 1 cylinder. Batteries had filler caps located high up on the rear edge of the case to prevent acid spilling, the carburetor float bowl had a special tube that drained gasoline into the vapor canister during shipment, and the windshield washer bottle stood at a 45 degree angle. Plastic spacers were wedged in beside the power train to prevent damage to engine and transmission mounts. The wedges were removed when cars were unloaded.
The Vega was hugely popular when it was introduced in 1970, however it quickly earned a reputation for unreliability, rust and terrible engine durability. When the Vega was discontinued in 1977, the Vert-A-Pac cars had to be retired as they were too specialized to be used with anything else. The Vert-A-Pac racks were scrapped, and the underlying flatcars went on to other uses.
The Deck Lid/Hatch for the Coupe Vega is a sought after piece for anyone wanting to make a Charger Daytona Clone, the dimensions to make the rear window plug are almost spot on exact!
The vega was the beginning of the end for GM. They did make good race cars.
My older neighbor has a sweet 1969 Charger and traded it in for a new Cosworth Vega. I think he was had.
His older brother sold his sweet 1966 1/2 Mustang and bought a Mustang II Cobra. Another bad decision.
One kid in HS had a tubbed out Vega wagon with a V8. His Dad built it for him but he kept burning out the clutch. He should have learned to drive with the 4 cylinder.
I love stuff like this. Shows that people can think!! I always liked the looks of the early Vega. Just too bad they were crap. But these days it's all fixable with the latest gen 4 cyl multi port EFI. And yes, those and Pintos helped define the 70's with all the V8 conversions.
GM should of went ahead and produced it with the V8.They did build one prototype version.But who knows if it would of been any better as it was a aluminum based 283 and we all know how the 4 banger did.
There's a guy around here that has an absolutely pristine '70 Vega with a small block conversion that I see at car shows occasionally. It's actually pretty cool.
cool photos gdrill, Ingenuity for sure.... I'm one of those guys who owned a couple V8 Vega's, they were fun as hell, quick as hell too, but crap stock, but I still like the body style... awe my youth
Now that is cool. I was in the rail industry for over 35 years, and this is the first I've seen of the Vert-a-pac. Ingenious.
Even though the Vega name ended in 1977, the basic car continued with the Monza name until 1980. I wonder if these rail cars were used to transport the Monzas as well?
And Monzas were made with a small block V8 shoehorned in. I'm told you had to loosen the motor mounts and lift the motor to change the spark plugs. Some people got a hole saw and drilled access holes in the inner fenders and put body plugs in them, took off the tire and changed the plugs from the wheel well.
I was one of the guys who "was gonna" put a V8 in one. I had a '76 wagon in '83ish. Flat black, hole in the exhaust. You could here my little airplane coming for a mile! I clearly remember one safety feature it had. We came out of a concert one night and it wouldn't start. Fooled around under the hood and found the oil pressure sender wire had come off. Put it back on and she roared back to life. Oh ya, youth!
Those are some really cool pictures. I never would have thought that they shipped them that way. There doesn't appear to be that much room to the top, so I'm thinking that the Vega or Astre were probably the only cars that would fit that way.
Hmmm, perhaps. However, by the time the Vega was phased out in 1977, the Chevette was already a couple of years old. It was even smaller, so I would have expected that they would take advantage of the same shipping methods if it was a money saver.
Here's a 1979 Monza wagon, and a 1971 Vega wagon. Not a whole lot of difference to me.
I thought I saw a thread on either here or Moparts where Chrysler used to ship cars in that fashion?
Cool pics. I vegaly remember those rail cars but didn't know what they were for. Thanks, now I know.
I worked for a dealer in '78 and someone traded in a '72, GT. Orange with white racing stripes (factory) It had a decal on the door handles, "Millionth Vega" Man I thought I found a collector until I saw another one just like it, then another? Never figured out that one.
Anyway I bought it for four hundred bucks, yanked the blown four banger, bought a Doug Thorley v8 conversion kit. Came with headers, mounts, ext. Found a 283 with a 350 turbo. Weekend project, fun car for sure. Sold it for three grand to one of a dozen guys that had to have it! Kids!
