Electronic ignition
1969superbee
9:51 AM
Vidalia,Georgia
I need some help here. What do I need to do to convert the rally dash cluster on my 69 superbee to electronic ignition.
The dash doesn't have anything to do with putting electronic ign on the engine, do you have a dash problem?
no, the tach wire goes to the coil. your gauges will work with electronic. I've had an electronic unit on my 69' 383 Coronet since 1997. No problems, some may change the regulator, But I found no need to. You will find it runs hugely better!
If your using a Mopar conversion kit you will be good to go. If you are going with an MSD I think you might have troubles with your factory tach. MSD makes a tach adapter if you go that route.
Yup....That's what I had to put in mine:
Thanks gpuller, I was thinking original mopar. I have an MSD on my 66' coronet, but have no Idea how it works!(it was on the car when I bought it)LoL
