30 is too much 20 is ok if you have a lot of cam but 15- 18 should be ok. are you sure you timing marks are good?the balancer slips somtimes and they are getting pretty old! do a tdc test and check your marks. if they are good i would set it at about 18 btdc then tune the carb from there. how much total do you have this is important if the curve in the distributer is stock you wioll have too much. but that is ok for tunnibg you carb you won't be under load. also you do disconect you vac advance when doing you timing right?
just for fun how far out do you have the air fuel ratio screw turned out? sorry to keep asking questions but it is hard to get a handle on whats going on over the computer! ha!
Charger360, no problem on the amount of questions, I just appreciate all the help.
I am worried the the balancer slipped, but when I checked it a year ago against TDC it was good. I will check it and move to 15-20 deg as you suggested and then take it from there. I am timing with Vac Adv disconnected and pluged at the carb. Dist is hooked to ported vac when hooked up.
As for the Advance curve... I have a new MSD Ready to Run distributor ready to drop in. I might as well set the advance on it now while it is out of the vehicle. I was going to switch ofver to it this weekend (although I think the current mopar unit is working ok). I realize I will have to spend some time dialing it in, but can you suggest a starting point for the advance curve?
On the Idle mixture screws, I have them 3/4 of a turn out from baseline (1-1/8), this seemed to be about the most improvement to vaccum.
Other item I know I need to do is replace the power valve with a 3.5. But if I understand how this PV functions, I assume it is not effecting the tuning at idle.
For a manual trans with high lift cam, what kind of idle speed should I be targeting? The engine smooths out above 950 but will idle as low as 700-750 without stalling.
so, this weekend I will..
1. Check TDC to verify timing marks still good.
2. Set initial timing to 18 deg
3. reset idle mix to stock setting and tune from there.
4. reset Idle, re-check timing
5. Check Vacuum
6. Report findings to all the helpfull people on FBBO
Let me know if I got anything wrong....I will leave out the distributor swap until the timing is more settled.
