GearAddict
Ok, I need some advice here... I removed my old unknown passenger side rear spring and mounted a new Mopar Performance XHD spring into the hanger and shackles but the mounting pad pilot hole is about an inch off of the locating pin on the new spring...I tried jockeying it around to line up, but can't get the rear axle to move enough to get it to drop in.
I went and measure the new XHD drivers side against the old spring and the pins are about 3/4 of an inch different in placement.
Not sure what to do at this point... I was intending on doing both sides, but one at a time. I assume the slip yoke on the axle would let me move the diff back an inch, but I'm worried that if I cut the u-bolts on the other side the diff yoke is going to nose dive... I suppose I could get another jack and prop it up?
Any suggestions/advice is much appreciated.
I'll post pics later tonight.
