bigmanjbmopar
Newb with a view
Well started to see lots of blue/white smoke on deceleration today
think these stealth heads the the pre fabbed stuff they used are finally wearing out after 3 years.
Have been playing with the PCV trying to run without for oil soaked plugs which worked, dried them right up running just breathers on each side. but went back to a PCV / breather combo on one side and just breather on the other. Now this big plum of smoke after a 120 mph run no smoke while cruising or from stop to start and just checked the oil level and it was a 1/4 qt low. it also had a strong pungent smell like fuel oil mix.
Not sure how to describe the smell of the oil as it looks golden in color. but does smell a lot. Thinking the valve guides or seals are **** now, any thoughts?
Wired thing is was my first impression of this was ring wash, 850 cfm double pumping big amounts of gas in the plenum then a decel washed some if past the rings? maybe got mixed in oil?
