benno440
life was good after all the problems and re-work I managed to put 3000 miles on the charger.
when on a car run with about 100 cars and my clutch pedal went to the floor, had to tow truck it home 200km ( pretty embarrassing especially cause most of the cars were chebbies and phords)
found my hydraulic slave cylinder on the clutch blew its seals. decided to go back to mechanical.
found some play in my custom front end, noticed my QA1 coilovers had there bushings blown out and destroyed.
all in this time looking for work and struggling with money, managed to scrap some money together to get all the gear to change back to mechanical clutch from brewers (great company)
turned up today, got the gearbox back in, started installing the z bar (very hard to get in, the ball pivot on the gearbox side does not screw all the way in as it bottoms out on the bellhousing)
finally got it in but it does not move very freely, hooked it all up and tried to press the clutch, NO WAY in hell could I depress that pedal so hard.
so my questions are:
is there anything that goes between the throwout bearing lever bracket and the front of the gearbox or does the lever just lever off the front of the gearbox ( or bellhousing I should say)???
should I remove the ball pivot from the bellhousing and shorten the threads to screw it in that bit more to hopefully loosen the z bar up a bit?
I have a Lakewood bellhousing and Kevlar single clutch, use to run hydraulic clutch, but not anymore unless the mechanical does not work.
not waiting for magnumforce to send me new coilovers hopefully (another great company)
semi rant over, looking for advice
