Mikes Runner
dolphin
1:23 PM
guelph ontario
Hi I own a 70 runner and.I have purchased a new wiring harness M&h for a raylle dash.I didnt have a raylle dash harness to start with.I have the cluster out and have figured some of it out,but i dont know where some of the other wires go.I could up load a pic and number the wires in the pic if someone could tell me where they go.You help would be greatly app.Thanks mike.
hi and welcome to the site ,post some photos of your RR ,if you search some of the past post on a wiring harness for your bird you will find several guys that have had post up with photos and of the wiring diagrams also :headbang:
Hi Is there a way on this site to go direct to a wiring harness pics
No, try using the search engine in the electrical section, maybe repost your question there as well, a factory service manual with wiring diagrams will still be your best bet.
DSC00405.jpgDSC00402.jpgDSC00403.jpgDSC00404.jpgView attachment 187905DSC00406.jpg
I`m with ya I would like to see this car love them 70 RR,GTX and the Sat.
OK, I am going to assume you question is basically "where the he** do all these wires go?"
I'll try to answer with some pictures and description, but I am sure I won't get it all. Hopefully this will be a start to help you out. As others said, the wiring diagram is important to learn and spend some time with. Hopefully my pictures can help you out.
Tis first one is the left side of the instrument cluster. The switch that is connected is the headlight switch, and the one that has just been disconnected is the dimmer. Lamp socket with two wires coming out of it is the brake light bulb. The green wire lamp socket is the left turn signal. The orange wire in the background is the gauge light.
This picture is looking over the top of the back of the cluster. The tick tock tach is on the left and the speedo is next to it. Orange wires are gauge lights (including my wrong green wire attached - this must have been a fix someone put in), red wire is high beam indicator. The grey wire coming out of the tack is the tack or clock wire - I forget which.
A bit further down the line. Here, the lamp socket with the neutral color is the right turn signal. The connector for the fuel, oil and temp gauges is next to it. It is not plugged in properly in this picture. It only goes in one way, so it will be obvious how it connects...
Here is the back of the tick tock tach. I forget which wire is which, but they only fit one way. Note that the spade connector farthest to the left in this picture has a nub on it so the plastic connector has a slot in it to fit.
OK. I will post this and then look for some more...
OK, here are a few more.
This goofy connector in the upper right foreground of this picture is the wiper connector. I have three speed wipers, so this is wiring for that. Notice that when the goofy connector is unplugged, two separate wires are left - they are in the background in this picture.
Here is a close-up of those two wires. In this shot, the one wire has now been disconnected...
Finally, this is the washer motor. Just make sure brown goes on the right connector and brown goes on the left connector. :icon_fU: (doesn't matter ;-)
I hope these are some help to you. Good luck with your project!
...Now as payment, let's see some pictures of your car!!!!
Hi .Thanks for the pics.Very helpfull.I will send you pics of my goat when iam done.Take care Mike
