- 9:59 PM
- Nov 20, 2013
- Ft Lauderdale fla.
If it goes away with the weight off the weels it's pinion angle.... makes a shushing that pulses through the whole car at a certain speed when the car is cruseing but not when accelerating or deceleration.... if you can drive through it it's pinion angle 99% of the time. If you're rear springs are 10 years old and or over 50,000 miles they sag and loose the strength up setting the pinion angle which is common to all rwd mopar s....
