Blown 67 coronet
I run a gear vendors overdrive behind my 727
I will throw my 2 cents in
built correctly a 727 will suit your needs
if you decide not to use a billet front drum I strongly suggest a shield
if you are doing a burn out in first gear and the tires hook up after they were spinning you will grenade the rear roller clutch and the front drum will be spining 2.42X engine RPM and have been know to explode just from centrifugal force.
i would not suggests a 4L65E, it is a weaker unit than a stock 727
besides the the hassle of finding a way to control it you will need to throw $ into beefing it up.
I like that unit because there are lots out there and I make money rebuilding them![]()
street strip with automatic featuresWhat would that setup run at current prices? Any difficulty in installing it? Can you use the OD in any gear?
What should I expect to pay for a 727 that would holdup to the torque loads the stroker is able to produce assuming moderate use with an occasional trip down the quarter?
995.00
with manual VB
1495.00
add 600 for a billet front drum
add 125.00 for a rollerized rear support
PM me with any questions
disclaimer....
I am not here to sell units I am retired a hobbyist now just trying to help guys out
guys that know me will tell u if you were close to me I would tell you pull unit come over you buy parts and i will rebuild it for you.
Can you engage the OD in every gear? For some reason I thought the unit replaced the Trans tailshaft.
The adapter replaces the tailhousing and the GV goes over the end of the output shaft. Yes you can engage it in every gear. GV calls it gear splitting. I don't use this feature. I have mine on a simple on/off switch. Look at their webpage, it explains it all.
