Radiator bushings
DodgeT
2:13 PM
WA
About to put my radiator in. I never did have the original, but I found a 26" numbers correct radiator. My car was factory with the 440 and RAM Air hood, but the 26" radiator does not seem to line up with the holes I have. Wouldn't a 69 Coronet R/T come with a 26" radiator?
Also, did these things bolt directly to the metal or did they have some type of bushing between them like my newer vehicles.
:headbang:
In my 69 RR and 70 Super Bee, the radiator is held to the support with 4 small bolts. The support framework has nuts welded to it, and the bolts go right in to those. Seems like the 2 bottom bolt holes on the radiator are open on the bottom end. So you can just loosen them and slide the radiator straight up to remove it. Top 2 bolts need to be removed completely. I haven't seen any bushings on any of them.
Your car could very well be set up for a 22" radiator.
No bushing. The flanged sides go right against the core support and the bolts used are 1/4-20 with the big captured washer.
Thanks for the feedback. I have been entertaining putting something between the radiator and core support just because I can. I have some extra padding that is normally used to go on the heater core tubes before it comes out the firewall. I was thinking of cutting them in half and using one with each bolt.
Maybe I should just bolt it up. I have two upper holes I think will work, but I will have to drill at least one hole to get the 26" to fit. Hard to believe it didn't come with a 26" radiator.
