Wookie316
Hi
Some may have seen my thread about my MP P5153524 head that is porous and leaking out the end. I managed to get it stopped and hope it will hold for the summer. Now thinking ahead to the winter when I tear it down to do a correct repair, I am looking for honest opinions on what I should consider switching to with the current build I have. I am not really wanting to switch the cam, but would consider if needed. I am really taking a hard look at the Indy EZ as cast heads, however I understand a person is best to get a set not finished from Indy because of quality control on their end. I am told I am better off to have them finished by a reputable head builder. So the million dollar question is where? Being in Canada it would be nice to have someone up here, but I am not opposed to shipping if needed? What are lead times on average at good machine shops? If I place an order now will I have for the winter to do a swap then?
Looking at continuing running the dual plane as I want to keep everything under the hood. So please give me your opinions on what direction to take this build. Below is the current build as is and what I am looking to accomplish. Thx in advance for your time. Feel free to PM me as well if you wish not to post to forum.
1971 Charger Superbee. 4500 lbs with a full tank and me in it. This is a car that will see mostly street use. I want my build to be one that I am not scared to drive 4 hours to a show yet make as much power as possible with current parts installed without compromising any reliability. Right now I get 16.95 MPG @ 70MPH & 14 MPG @ 80 MPH. Milage isn't a real concern in the build, but that is what it does currently just for information purposes.
MP 452 Aluminum head P5153524 84cc
Comp adjustable rockers 1.5 ratio 1621-16
Comp hydraulic cam 21-228-4 .545 lift 241 intake 247 exhaust
Performer RPM intake
Holley 870 Street Avenger
MSD distributor and 6AL-2 box
Callie's Dragonslayer crank 4.250, 2.750, 2.200
Scat H Beam 4340 Rod 6.535
Custom Diamond Piston 4.375 .990x2.930 Pin -24.0cc #52409 with 84cc it is supposed to be 9.5-1
Cometic Head Gaskets C5461-040
Power Bond Balancer
TTI Headers
3" TTI Exhaust with Magnaflow Mufflers
McLeod Flywheel 464100
McLeod 6913-07 RST clutch
McLeod 1400 series Hydraulic release bearing
Tremec TKO600
3.91 8 3/4" with 27.4" MT's ET Drags 295/45R17
If I have missed any info that is important, please let me know.
Power Bond Balancer
TTI Headers
Tremec TKO600
