clutch replacement
r70rr
5:55 PM
missouri
Need to change the clutch setup in my 70 roadrunner.
I, was told that you need to support the engine to change out the clutch.
Is it really needed to be supported and what is a good way to do it if you should have to support it.
I've always blocked up the rear of the oil pan. once you pull ther trans there is no rear support for the engine.
Not overkill, but best to put supports at both sides of the rear of the engine block. Not at the pan.
Lol...yeah...2 cents.
