2059
- 6:54 AM
- May 4, 2012
- North Central Indiana
I can't imagine there isn't a "Pipe and valve" guy on the site that won't weigh in on this (especially you industrial and oil patch guys).
I think your orig. post ND74 brings to light the importance of recommended piping for any pressurized delivery system. There are several "schedule" ratings and a use for each. Your photo looks like SCH 120 pvc sprinkler application. Schedule 40 pvc is used for residential plumbing, most dwv and some pressure delivery. I'm sure you can get away with it for compressed air, but I wouldn't. Schedule 80 is heavy industrial use. PEX line is polyethylene, damn near indestructible however, I wouldn't use it for compressed air because of the fittings and the explosive energy/pressure of compressed air. No residential water system delivers the static pressure plus there's a difference between pneumatic and hydraulic energy at failure. Iron pipe is the safest for rigid piping, rated rubber hose for flex. there are extruded aluminum systems for air delivery on the market with engineered fittings that are top notch but expensive.
To each his own. IMO safety first.
