Blown 440 for street/strip
32PB
11:38 AM
vernon b.c.
Just in the process of assembling my engine. 440 , factory block, stealth heads, 671 huffer. First time with forced induction. Wondering if any racers on here have experience they may want to share on gaskets/sealing when making boost. Thinking Cometic head gaskets and just good felpro gaskets everywhere else. Main concern is with rear main seal, as ive had issues there in past. Would a rope seal be a better or worse idea in a boosted application?
Any experience and suggestions will be appreciated. TY, Paul
I've had a blown 340 since 1985. If it doesn't run into detonation the Fel Pros work fine. Keep the total timing around 30 degrees and you should be OK. Water injection in a nice feature for pump gas to ward off detonation. Make sure you have a BIG radiator and good fan. Blown motors make heat.
Good Luck Doug
Good Luck Doug
Thanks Doug, I am concerned about keeping it cool. Small radiator and Ive had issues in the past with over heating. Trying a slightly larger rad (all that current rad shroud will allow), in aluminum this time.
By the way, you're set up looks very Kool! I imagine the blower must work well with the w2 heads. I use to race a 340 duster that I put w2's on and couldn't believe the difference.
Not W-2, Headers are W-2. Made a set of adapters. Car runs 11.0 in street trim at 3875lbs.
340,home ported 308 iron heads .550 cam, 8-1.
