Don't worry about hijacking guys, it's something others are pondering so go for it. Tonight was a great night for getting r done! Having plenty of time I welded everything up on the cross member and went to town on the tranny mount. First I want to show something very interesting, I knew Goon wanted to use the forward shifter location so I thought it being a Viper trans will there even be a provision for it.................Nope. Here's a pic of the insides of both locations.
I made a trip to a buddies house to drop off some parts and made this little go no go gauge or you can just call it a paint stich haha. He has a 69 RR with the same driveshaft in it so I cut a paint stick to fit tightly between the floor and the donut on the drive shaft so now I know the height. I was close, had to drop it about a 1/4" which was great because it freed up some tight spots.
Sorry the computer is screwing with me and I can't put text to the individual pics so I'll try to explain. The pic where I'm holding the ruler shows how far in from the center of the hole in the bottom of the cross member to cut it off (about 1 3/4") on both sides.
The ears bowed inward from the welding so the pic with the bolt in the cross member is showing how I pushed them out for a tight fit.
Dropping the tranny had one issue, you can see that the reverse lockout is now touching but I don't have the plate in front of the bell housing right now so it will go back 3/16" or so when that's in (may need some grinding).
The last set of pics shows my lazey approach to building a tranny bracket haha, Hey it worked! With this tranny being so fat I really tried to tuck the tranny mount up in there like a G string. Still need to drill the extra 2 bolt holes in the frame and add sleeves in the cross member and drill the tranny mount holes.
There's one really close up of a weld, I wasn't trying to show off a weld but when I flipped the bracket over to weld the other side that was the weld that had penetrated threw (thought it was pretty cool seeing how I can't weld that good on the front haha).
