66belveder
Just had 1968 383hp block rebuilt, I believe head gasket is leaking, my first question is does the head bolts us any sealer on them or are they just installed dry???? with no sealer. There is no anti-freeze in oil, Anti-freeze is leaking out between head and block under # 4 & 6 exhaust header tube.
Which head gasket should I try to use next when I pull head off???? I'm using stock head bolts also, should I use a washer on the bolt just to make sure I'm bottoming out head bolt??? I'm just thinking about just pulling both heads replacing gaskets and use new ARP bolts, engine does not even have 5-minutes of run time on it, not to dam happy with the builder right now but before I clime up some body's you know what . ANY SUGESTIONS FOR FIRST TIME MOPAR OWNER WOULD BE HELPFULL, THANKS **heads were also redone by different person do I send them back to have them rechecked** The first time I do not dyno a engine or run on engine stand it leaks, never again will that happen again
