Big thanks to Hammond . . . great forward strut suggestion . . .
Well . . . the install of the forward struts ( being my first time ) is taking it's time as I'm trying to make sure that I've covered all the bases and don't end up with any surprises in the end . . . and least try not to have surprises.
So here's the alignment that I had on the firewall . . . initially . . .
Then I get a PM from Hammond with a suggestion -
unless you want a lift off hood, put the hood springs in the car, in the down position, and make sure they'll clear . . .
experience talking since he "almost" did the same with his 67 Coronet . . . so I put a measure on it . . .
Then put the hinge in place ( in the down position ) . . .
And you can see how close the spring is to the strut . . .
Ok, trying to hold everything in place, including the yard stick, and shoot the picture on the camera . . . it doesn't look "too bad", but if you look at the top picture, you'll see the sharpie marks where it needs to go, compared to the original alignment ( I was off by about 1/2" . . . that would have been really bad ! ! )
Thanks Hammond for the heads up - you saved me from making a pretty big blunder !
