70 RR
I have heard guys saying they run 15lbs in their ETs. Does this sound about right?
That depends on the car. I tried 8lbs once because a guy in a Cuda was doing that and hooking up nice. Trouble is my GTX had more overhang at the rear and different weight dispersion, didn't handle well at all. Ended up running around 13-15lbs. Once again, different factors determine pressure - heat in the track, ambient etc...
I talked to tech at M/T and they told me NOT to run less than 12-13lbs in any M/T tire that is 28" tall or less" with a HEAVY CAR...such as 3500lbs or more. M/T TEC told me that lower than 12-13lbs with a heavy car would just crush the tires and make the center cup up and get contact on the outer sections of the tire. But with a tire that is TALLER THAN 28" can run the lower air pressure even with a heavy car. This is not my opinion...just what M/T Tech told me.
My car is 3690lbs. it hooks best for me with 16 lbs.
I plan on repeating!
Ron, My life will be complete when I get my new stroker motor in my Coronet and pull the left front wheel on the launch like you do. My new 512" motor is being built to my specs to be right at 600HP and 650FTLBS of Torque. I don't really want more because I want to take it easy on my trans and my 8 3/4 rear end. I just installed a complete CAL TRAC system with MonoLeaf springs/Traction Bar Setup and their 90/10 front shocks and their rear shocks. I also just put on a brand new set of M/T ET DOT slicks 28x13.50x11.25 wide and have them screwed to my Weld Wheels. I plan on running 12-13 lbs. I am hoping for 10.70's.I actually run radial slicks all the time and they hook good for me at about 16 psi. It took some getting used to when years ago we would run like 8 lbs in the old bias slicks. I run my tires up to 28 and drive them on the street and then drop them to 16 at the track where they work good. Ron
View attachment 247419View attachment 247420Ron, My life will be complete when I get my new stroker motor in my Coronet and pull the left front wheel on the launch like you do. My new 512" motor is being built to my specs to be right at 600HP and 650FTLBS of Torque. I don't really want more because I want to take it easy on my trans and my 8 3/4 rear end. I just installed a complete CAL TRAC system with MonoLeaf springs/Traction Bar Setup and their 90/10 front shocks and their rear shocks. I also just put on a brand new set of M/T ET DOT slicks 28x13.50x11.25 wide and have them screwed to my Weld Wheels. I plan on running 12-13 lbs. I am hoping for 10.70's.
sorry not to get off subject
Calvert CalTracs recommends not using
Super Stock Springs combined with CalTrac Bars,
kind of defeats the action/function of the S/S springs,
IIRC they said use/recommended
either use the stock type OE multi leaf,
or their mono leaf springs &
not the S/S springs
doesn't mean they would work, just not recommended
Anyway carry on
when I was running M/T Drag Radials 315/50/15's with my 479ci 68 RR
I ran them mid 20's psi on the street, if I was on curvy roads like 25-28psi &
usually got best results at like 16psi at the lowest point,
I tried with any success on concrete starting pads,
little loose & washed out/wandering feeling on top-end thou &
18-20psi was pretty good/optimal for @ the track, depending on specific tracks,
that's if there was decent prep done
You say you used Cal Trac shocks both front and rear? 90/10 front and 50/50 rear correct? My car is primarily a street machine, I am not going to set it up as a full race car. I have cal tracs with the super stock springs to try and help launch my 542....BTW, all off you have awesome cars, thanks for your input!
View attachment 248034View attachment 248035View attachment 248036
I placed 2nd last weekend at the Summit Piston Powered Autorama Show at the Cleveland IX Center. I was in the Conservative Hardtop 70-79 Class.
