Mopar-Charger
The Engine:
Mopar 360
750 holley
Ported + 2.02 heads
Air Gap RPM intake
Headers
High volume oil pump
Stock rockers
727 TF tranny
Here's the problem. I can get the car to idle fine, however with any gas in D, the car stutters and sounds real loud but no rpms. Almost like you give gas just to keep it alive. Then when you let off the gas, it drops down to 300 RPM and nearly dies. Have to keep tapping to the gas to move. However, in park, it runs fine.
Second problem is there is this clunking noise from the engine. It's random but it's loud and there. you can feel if you put your hand on the engine.
Engine was rebuilt prior to this problem. All stated in the description is what was added. Ran fine for about a week. then out of no where started doing this. I swapped the plugs, Set the timing right 10-12 initial 34 total. Idled fine, but as soon as it went into gear it was loud almost like a "pop" every combustion rather than a nice idle.
I'm stumped. For those who have followed my other thread about the rockers not oiling, i fixed that and got her running again to this. Not sure where to go.
Mopar 360
750 holley
Ported + 2.02 heads
Air Gap RPM intake
Headers
Stock rockers
727 TF tranny
