jenkins71
Hey guys. Today I put my shifter on to my four speed.
Car is a 71 Charger with a 440. Buckets. Was a console automatic, but am gonna ditch the console.
Okay, so I got my linkage set up! I did everything on the cheap, including buying a used original shifter and a set of rods and levers from a guy her on FBBO. They are a kinda shoddy repro but do the job!
Ok, my question. In neutral, the shifter rests in the 3-4 gate. In other words, if you push the shifter directly forward from being in Neutral, you are in 3rd. If you want to get into 1st gear, you move the shifter to the LEFT from its resting Neutral position. Seems kind of weird, like at "rest" the shifter should be below 1st gear. Is this normal, or weird?
Also, it is kind of hard to get the shifter over to the Reverse gate. Then when you do shift it into reverse, it kind of clicks twice to get it into reverse. Is that normal??
Thanks guys! I just rebuilt this tranny and want everything to work fine with the swap from the 727!!!!!
