wildtom
New Member
Hi !
I need some input here ..
I have a 1970 superbee and my machine shop have done a new engine with following specs
sis 440RB Block
500ci Stroker Kit mit 4.15 Hub
H-Beam Rods 6.760
Ross Pistons
Compression 10.5:1
Edelbrock Aluminium Heads
Competition Cams 225-4
mechanical Lifter
Competition Cams Roller
Manton Pushrods
TF727
Converter TCI 142200 Hemistyle with 2400rpm stallspeed
I did a dyno run yesterday on a dynotech and we came out with max 387 HP on the wheels @ 4200RPM and a tourque of 560lb @ 2500RPM
I need some input here. Are the numbers ok ? I would have expected approx 500 HP on the wheels. So i am dissapointed - my engine shop sayd that the numbers are ok and that the engine itself delivers approx 500HP due to the loss of approx 25% through the driveshaft
So what di you think ?
Ok or not ?
Thanks !
sis 440RB Block
H-Beam Rods 6.760
Ross Pistons
Compression 10.5:1
mechanical Lifter
Manton Pushrods
TF727
Ok or not ?
Thanks !
