Amp gauge/alternator modification
texas69bee
8:14 AM
texas
I am sure some of you have seen this modification http://www.madelectrical.com/electricaltech/amp-gauges2.shtml. My current alternator is rated at 90amps, I believe I need a 10 gauge wire going from the alternator to the starter relay. What size fusible link would I need?
The wires going into the bulk head are currently 12 gauge, am I right in thinking these will be fine because they no longer receive full amperage, just what is needed?
100 amp maybe pushing it with 12 ga. wire thou
I've done sort of that mod to a few of my cars;
But a 75amp. alt. & I used a 8 ga. wire
going from the main output 1/4-20 stud on the back of the alt.,
back to the starter relay 1/4-20 large lug, helps to shorten the path/less load,
all the rest of the OE wires are still there, still intact too...
It helps to lessen the load from the alt. & wiring, especially under-dash & amp ga....
But I still have the amp ga. inline, haven't removed it yet, it works great...
I have a rear trunk mounted Battery too, made a world of difference...
Make absolutely sure you have really good & properly sized grounds/straps too,
battery to chassis/body
& engine to chassis/body,
always make sure no paint between the connections,
I use star washers & dielectric grease always too...
I recommend people to go to Mad Enterprises site go thru the list below
@ http://www.MadElectrical.com/electrical-tech.shtml
Dodge amp. ga. stuff is near the bottom of the page, good/must read,
also use them all the time for various electrical tech stuff & supplies...
I actually replaced the fusible link with a resettable 10-15 amp breaker
{20 amp breaker on my current wiring, but it's a custom harness now too}...
My cars wiring was hacked by the previous original owner...
Still needs some stuff I'll get to when I install my new custom gauge panel...
I have it on my current 68 RR too,
make certain no bad/loose wires or connections to the amp ga.
& make sure all amp ga. connections are clean/tight,
the large black wire that feeds all the electrical under the dash,
thru the amp ga. in thru the firewall bulkhead connection,
& make sure all the bulkhead connections are clean too,
make sure to use dielectric grease on all connections too...
done it to a few cars now no issues yet, even had a volt meters/ga. inline too
everything goes thru the big black amp ga. wiring underdash,
I couldn't be more serious, to make absolutely sure !!
it's all really good connections & covered properly, I solder & shrink wrap...
it can start a serious fire, it's no joke
Sorry I didn't do that exact mod, they show, but it's easy too...
But if you have any real questions just contact them,
they will/should usually help you, probably recommend a part/piece they can sell you too...
Done a few of these wiring upgrades also, if I remember correctly Mark recommends a fusable link 2ga difference than the circuit it will be protecting ( 10ga wire needs 14ga link, etc .... )
I did the MAD bypass on one of my cars. I used a 60 amp alt which needed a 10 gauge wire from it to the starter relay. With a 75 amp alt, the charts show you should use a 8 gauge wire, with a 12 gauge fusible link.
I also highly recommend installing a relay for the headlights. That way you aren't pulling as many amps through the headlight switch.
I did manage to get a hold of Mark Hamilton, the owner/creator of MADELELECTRICAL. Great guy, very knowledgeable but you better have some time on your hands cause he likes to talk and teach.
Question for you that made the upgrade.
Can you use a heavier gauge wire until you upgrade the Alt?
Like i have a Std i think 37 amp Alt,can i upgrade the current wire to 8-10 gauge and leave my std Alt on til i change to a Higher Amp Alt?
And if i need to Change Alt,which style brand is recommended for a stock look?
Yes
you could use the heavier ga. wire, prior to the higher amperage Alt. conversion...
Ii sounds like you are doing more of a restoration/alteration
BUT;
I modify most all my cars & used a dual field alt, 4pin ballast & an appr. M&H harness from Year One
{I also used a CEI electronic ignition too & electronic regulator from 1973 @ latter,
it's far better system than the 68-69
I used a Chrome case 75 amp Powermaster or MSD 100 amp Alt.'s,
the OE style look {Chrysler built their own}
68 OE 37amp. had a Chry. case/part# 2642537
for 69 OE 37amp. had a Chry. case/part# 2642944
& which brand question, of repop's, somebody else may give a better answer...
good luck either way
  • Chrysler Electronic Ignition Wire Diagram 4 pin Ballast & Electronic Volt. Regulator.jpg
Ok Thanks Budnick
Also to use an 8 Gauge wire we should use for a Fusible link 12 Gauge or use what size Circuit Breaker?
where do buy relays for the headlights and the heat sink rap that goes on wires. thanks
where to you buy relays for headlights?
read the mad by pass article understand everything but if you by pass the factory ammeter what do you do for a ammeter?says nothing about adding a volt meter can someone clarify please. thanks
what would be wrong if you added a fuse link from the alternator line and a fuse link from the battery line that goes to the ammeter,wouldn t that protect the system from a fire hazard? just asking i do not know.
Moparjonny, I don't believe it will work the way you think. The amp meter is receiving a full load already and that it what is causing the melt downs. The fuse would work for a surge. Any questions you may have, Mark will have the answer. If you want parts from Madelectrical, you have to call him anyway.
twinscrew698... Mark will tell you that at 90amps you can get by with a 10 gauge wire if you are not using a clutch fan. If you have to red wires coming from your battery, he will tell you to put in a fusible link(14 gauge) to the one that goes to the starter relay. From the ammeter you will still use a 16 gauge fusible link. When doing his modification you can use a 10 gauge through the bulk head as well. The current is being shared by 2 wires. I went with the powermaster round back 2field alternator as budnicks suggested. Minimum rating is now 90amps per there website. The upgrade wire harness I used is M&H from yearone.com. It is set up for a 4 pin ballast resistor but the ecu boxes coming out now are a 4pin that uses a 2 pin resistor. The other resistor is now internal.
Texasbee.Thanks for your input, now i have a very good idea of what i am going to do.
