- 9:37 PM
- May 14, 2011
- On the Ridge, TN
Wow, lots of good information here, but I get lost in all the numbers sometimes.the older mopar electronic distributors had 13 degree advance plates which means 26 crank degrees. i usually run 8-10 degrees initial with these to get a 34-36 degree total. stock springs will bring it all in around 2800rpm. basically good enough for that cam. the comp 270 is a short cam ground 110lsa with 4 degrees of advance ground into it. the 270 along with comp cams magnum replacement and xe268 close the intake too early with anything over 9:1 compression. this does make for very good vacuum, maybe too much for the vacuum advance; but thats fixable. the stock magnum cam is ground on 115lsa and closes the intake at 71ABDC. the 270 will close the intake at 61ABDC; very noticeable difference. the summit 6401 cam is ground on 114lsa and closes the intake valve at 74ABDC (very good choice for stock or near stock engines. has about 10 degrees more duration at .050" lobe lift and .200" lobe lift, with a little more lift at the valve with absolutely no bad driving characteristics). from my experience these big cube engines in near stock condition don't want short cams with tight lsa's and early intake valve closings; unless the compression ratio is down around 8:1.
Not to doubt what you've written, but from what I can find on them,
the factory cam for the 440magnums had specs like:
duration: 268*I 276*E
lift: .464 I&E
separation: 110*
the Magnum 270 Comp Cam I just put in the motor:
duration: 270* I&E
lift: .470 I&E
separation 110*
I don't know squat, but that doesn't look like much difference in cams to me.
Certainly not enough to fight me like the dickens tuning the thing, that's for sure.
Ought to set up pretty much stock, I'd think?
