My 69 Coronet project
I haven't dne it yet but will in the near future but read that you can leave the bottom stop out and lower the glass to install the felts then raise he glass and install the stop.
http://www.chargersourceguide.com/sidewindows.html
That's a helpful link. Nice of the guy to cut away the outside sheet metal just to illustrate his point.:toothy10: If you're just going to be replacing the felts than that's a good way to go. My quarter glass is out already so the felts go in first. FWIW, when I disassembled the car I took the quarter glass out before I took out the rollers and regulator. With the garnish molding off there's enough space to allow a box wrench to fit inside.
I can't remember the trim the Coronets have, but if it's similar to the Chargers. it's best to put the outter trim on first, then the felts.
Coronets are the same as the Chargers - the trim bolts on and then the felt snaps over it.
Just finished it tonight.
I'm getting all giggly inside seeing the progress................... (sorry)
I'm with you Superfreak. I'm so anxious to get the Coronet on the road there are nights I can't sleep thinking about it. But it's a slow process. For instance, I started reattaching the chrome trim, stepped back to take a look and couldn't do it. The ss looks too dull next to the paint - so I just bought a polishing kit and I'm gonna polish all the trim. Just like your tag line says….
I hear ya on the no sleep nights, had many of those during the major part of my build. Good choice on polishing the chrome, you will be happy that you did. Now......definitely continue to take your time so as to avoid scratching the new paint.
I should have said stainless steel trim, not chrome. The chrome bumpers, etc. will be polished with Mother's, no re-chroming. The kit I bought was for polishing the stainless steel, aluminum, etc. Before the motor goes in I'm gonna try polishing the intake manifold too.
I figured it was the stainless after I typed chrome.........it's very hot here.
Whew, so much time, so little progress. Finally got the quarter windows in along with the weather stripping and trim.
Also painting the inside of the doors
Great looking Coronet, love the color. Look forward to seeing it finished as I'm sure you are.
Is that a big scratch I see??????
Hey now, that's not funny. No scratches, just a reflection off of the mirror-like finish. lol..
Thanks Riverdawg. And your car looks bad-***. I love the T5/T7 color scheme; I was originally going to repaint my Coronet the factory T7. It was Hunk2Elk's resto thread, one of his posts had a picture of a Charger in Copper Sunset, that pulled me in the other direction.
Well 12 pages in and all I can say is WOW, fantastic job.. Pulling my Engine and trans this weekend.. Can't wait to see the engine build!
Thanks Derwud. It's my first rodeo so it's taking a lot longer to piece the car together than I planned. The engine is the shop waiting in the que. I'll post pics once it's started, and hopefully a video of the break-in.
Made a lot of progress this week; Maria's cousin came over yesterday and helped me move things along.
The interior will be insulated with Fat Mat Rattle Trap sound deadener. I'm planning on covering the firewall (done!), front and rear floor pans, wheel well humps, interior side of the cardboard trunk divider, and roof. I measured needing about 66 sq. ft. of material; 75 sq ft was the closest price point and any left over will go into the doors and/or the top of the package tray. The stuff is very easy to work with, very malleable, easy to cut and trim. Fat Mat supplies the safety razor and roller wheel; you need the wheel to roll out air bubbles and get a good seal at the seams, but it's cheap. There are better ones out there for installing wallpaper, etc.
Got the factory insulation installed over the Rattle Trap. The upper insulation secures with spray-on adhesive and the bottom secures with the plastic rivets. I had covered the mounting holes with the Rattle Trap so I had to use the engine compartment side for reference. Note: Four of the attachment points are behind the fenders (two each side); fortunately I haven't installed the mud guards yet so I was able to find the holes; if you're planning on installing sound deadener and your car is assembled then mark the hole orientation beforehand.
Cleaned up the wiper arms, then prepped and painted. I didn't take apart the pivot points, just cleaned with Simple Green and sprayed with WD 40. In reality living in CA I may never turn the wipers on. In the 3+ years I've owned the Dart I've maybe used the wipers 5 times.
Yesterday we got the brake assembly, power booster and m/c, and Classic Air heater box installed. Way back when, I had purchased the booster and m/c separate from the disc brake conversion kit because I wanted the Bendix style. Most of the all-in-one kits seem to come with GM style boosters.
The CA heater box was slammed home on the first try. I'm very impressed so far with the engineering. I had bench calibrated it a few months earlier so it was ready to go. The unit is surpassingly light. It uses the OEM stud on the interior firewall, although you have to use their bracket. You need two people, one inside and one in the engine compartment to guide the hard lines through the firewall. But it literally took minutes to position; the bracket needed massaging but that was about it.
Finally. Something's hanging off the firewall!
This is the last work I'll be doing on the car for a week or so. Tuesday we're headed for Ohio. Gonna catch a Toledo Mud Hens game, visit the Rock n Roll HOF, the Pro Footbal HOF and then THE NATS! Hope to run into you guys at the show. You can't miss me, I'm the old guy wearing the Mopar baseball cap.
Nice work and congrats on all your progress.
FYI, if you are planning on installing electric windows and/or door locks drill your holes in the A pillar and door while the doors are off. I just did mine this weekend.
Thanks Roger. In the beginning of the build I was thinking about installing electric windows, very convenient. My wife talked me out of them - she doesn't want the car to feel too modern. I hope you do a thread on the install I'd be very interested in how it turned out.
See ya in Ohio! Your going to be right in my neck of the woods, I literally live right in the middle of everywhere you've mentioned and thought I should mention you'll be awful close to Summit racing while at the Football hall of fame. Have fun
Your Coronet is coming along pretty well and I'm getting anxious to see it back on the road. Great work, keep it up.
