- 8:22 PM
- May 14, 2011
- On the Ridge, TN
Thanks for hanging in here with me, JB.I had an edelbrock 800 AFB carb once had a weird stumble at a certain RPM, no matter how many combinations of rods and springs / jets I tried which was every possibility it just wouldn't fix the issue, a new QFT 850 was good, I use a QFT 780 vac sec now for just cruising but have the 850 for fun timepoint is maybe it's just a bad carb out of the box? I still think its electrical though
Electrically everything is new, including the coil, ECU, heck man short of pulling the new MP distributor, I'm at a loss there - and I'm darn close to picking up a regular ol' rebuilt stock electronic distributor and tossing it in there just to eliminate THAT possibility.
Oh, I got a response from Holley. Not sure what to make of this:
"Thank you for contacting Holley Performance Products.
I would suggest dropping to a 5.5 power valve and blowing out your high speed air bleeds with compressed air. Sounds like there may be a bit of varnish in the bleeds. See it that takes car of you. If not, let me know and we will go from there.
Sincerely,
Jeff Teel"
I'm confused about the power valve suggestion - isn't the purpose of the power valve to aid with the initial demand for lots more fuel when you step on the throttle?
Guess it couldn't hurt to take the new, shiny carburetor off and blow out all the orifices with brakleen...
but something is telling me I got the junior member of the tech support team at Holley.
