- 8:23 PM
- May 14, 2011
- On the Ridge, TN
Well at this point you are still not sure what the cause is?
What I know / did about fuel lines / clamps
I bought this stuff to update the 5/16" factory line just to make sure delivery was on par and since the car was 44 years old and I could not look inside I just upgraded it, if you shop around you can find it cheaper I paid $25 forgot where free shipping I think.
http://www.jegs.com/i/Moroso/710/65330/10002/-1
As far as clamps go I switched to these for fuel, yes they are size specific but they work! and works well, I didn't buy from this place this is just an example I think autozone or orileys sells them.
http://www.karishmasteels.com/Galvanised-Hose-Clamps.asp
http://www.mcmaster.com/#standard-hose-clamps/=yir0lk
http://www.directindustry.com/prod/mpc-industries/product-65240-719197.html
http://www.kartek.com/Product/3228/JAMAR-Black-Aluminum-Hose-Clamps.aspx
Yep, the GTX has the 3/8" fuel line all the way up from the tank like it's supposed to; found that out when I swapped the tank and pickup.
The fuel return line has been disconnected and capped by previous owner, so I put a vented gas cap on the tank and made sure the tank vent lines were in place and clear.
Wish I had the original metal line from pump to carb, but I'd have hacked on it because of the Holley anyways. I don't care for the fact Mopar ran everything on the passenger side of the front of the motor, though - alternator/distributor/heater hose lines make for a tight squeeze for the fuel line through there, part of the reason I did the fuel line like I did this time.
Yep, mystery continues until a parts store opens up and I can get some clamps...
