74Beeper
So, my Indy small block 440 with a Mod-Man intake did not come with the water pump bypass port drilled/tapped in the intake. I've read several different opinions on this whether it is actually needed. This engine has a high flow water pump and thermostat and sees 7000rpm+ frequently. The other day, I hit 7000 and popped a brand new heater core dumping 2.5 gallons of antifreeze in the passenger floor well. (What a mess)
Im thinking a bypass hose would keep this from happening again. What else does this hose do and what are the benefits of not running one as opposed to running one?
