- 10:39 AM
- May 14, 2011
- On the Ridge, TN
Hello?
I been abandoned...
I been abandoned...
Well, it appears Edelbrock has the market price-fixed on their 1812 Thunder AVS. No matter where I look, the thing is going to cost $401.59 plus.
None of the usual discounts at Advance, Autozone, etc. apply to it.
That makes the decision even tougher.
Think I'll pursue the Carter AVS I've linked to in this thread first. Willing to take the risk for half the money.
As bad a taste in my mouth as I have for Holley anything right now, that might be the most economical game in town right now, at least for one somebody has at least gone thru.PS I would STILL call promax and buy a rebuilt holley off of him, he will dyno tune it and you will just bolt it on, probably for less than the $400... That edelbrock aint' gonna treat you better out of the box than something someone already dyno tuned for you...
Holy cow, really? What a generous offer! Perfect scenario for me, too - if the engine does the exact same thing with a different carb, it'll tell me a lot.I can dig around this weekend and I think I have an edelbrock or carter carb sitting on the shelf that you can play with and see how you like it before you dole out big money??
I'm game if you are. THANKS!
The car is quite drivable and we do so often. It ain't "right", but after all the heartaches, work and cubic $$$ expended, I'm gonna drive the damn thing.just buy a carb already ,lol.. I would have went to autozone and pulled one off the shelf, just to be able to drive the car by nowshipping a carb back and forth is going to be $50 alone and then you may still need a carb...
Done, sir.Send me a PM broski
I dont check the board everyday.
Current timing is set at TDC (again), at least as indicated on the marks. I set it by ear for max smoothness @ 3000rpm.
If I hook up the vacuum advance, she gets all jittery at part-throttle, acting like it's too much advance.
I guess I can rule out distributor as a cause, at least.
Sigh.
I think I've eliminated ECU by trying three different ones - two Mopar orange ones, one new, one used, and now a "store bought" stock non-performance new one as well.That sounds like maybe ecu? Some boxes do not like vacuum advance at all, rev n nator being one...and that is what happens. Jittery at cruise with vac line hooked up. Mopar chrome box is a good unit and it plays well with vac advance. Are you sure your timing marks are correct I'd check tdc with a piston stop.
When buying parts stick to summit-jegs-Mancini, rinse and repeat.
