- 9:26 PM
- Jul 1, 2015
62MAX,
If your reasoning is true, why did Mopar design the cooling system for a big block applications with A/C with an overdriven water pump with 8 impeller blades? The reason for the 6 blade water pump is LESS horsepower being consumed which is OK for drag strip applications. Velocity is a determining factor for heat exchange...be it liquid to air or liquid to liquid or air to air heat exchangers. However, for liquid to air heat exchange, velocity, specific heat of the cooling media (both on the liquid and air side) as well as the surface area of the heat exchange component (the fins per inch) are important factors in determining just how efficient the heat exchange is. One must perform their own due diligence with regard to what is ultimately selected, rather than relying on a friend of the next door neighbors, brother-in-laws cousin..... but this is just my opinion.
Cheers,
RJ Renton
Cheers,
RJ Renton
